spoon ecu, program changes what?
Old Jan 7, 2003 | 09:42 AM
zivvy's Avatar
Default spoon ecu, program changes what?
I have a shop that has a spoon ecu that came from some motors from japan.. its genuin has the spoon tape seals and all but my question is what is different from my us spec h22 ecu higher redline? fuel cutoff? etc...
background info:
93 prelude
engine 94 h22 usdm, I/H/E headwork with ported IM, vafc... im still building the motor so modifications dont stop here
Old Jan 7, 2003 | 12:04 PM
bryant's Avatar
Default Re: spoon ecu, program changes what? (zivvy)
The ECU is not just chipped, it has its own stuff.
Yes, has higher redline, better air and fuel, and not sure, but might move the vtec x-over.
Old Jan 7, 2003 | 12:05 PM
eg6ajk's Avatar
I have two different variants of the Spoon program, but both are very simliar (Spoon does that usually to all of its ECUs)
vtec points seem to be in 5-5.3k rpm range
rev limit in 8.2-8.6k rpm range
fuel maps and ignition maps are also improved (for once spoon acutally made a good streetable program which makes power)
Old Jan 7, 2003 | 02:33 PM
zivvy's Avatar
Default Re: spoon ecu, program changes what? (eg6ajk)
but i have a APEX'i VAFC so taht covers vtec and fuel map right? so all i would gain is higher redline and maybe higher or aliminated speed govener?
will this uce dampen any tuning i do on the vafc also?
Old Jan 7, 2003 | 03:55 PM
Kataku2K3's Avatar
Yea you're correct all the prog is going to do really for you is remove the speed limiter and raise or remove the rev limiter but it dose also have control over the timing maps... The new prog most likely has upgraded fuel and timing maps which will affect you if you have your VAFC tuned for your setup right now... I personally hate the Spoon progs, but that's just me... I would just stick with your VAFC, unless you just want to raise/erase your rev limit or speed limiter.... Latez
brototoy
Dec 1, 2007 08:16 AM
jessevtec
Jul 9, 2003 03:58 AM
zivvy
Jan 7, 2003 01:47 PM
chigsu
Dec 27, 2002 10:29 PM
3gLudeH22A
Apr 25, 2002 07:17 AM
