Speedometer not working
Old Apr 7, 2009 | 01:33 PM
chad's Avatar
Moderator
Default Speedometer not working
1995 honda civic dx
ecu has voltage from vss
replaced ecu with known good ecu, replaced vss with known good vss, replace cluster with know good cluster
b2 at guage cluster yellow/blue is not grounded out at ecu b10. is there a fuse for the speedometer?
voltage from .0 to 4.5 while driving at ecu a26 and b10 but speedo doesnt' work.
any suggerstions?
Old Apr 8, 2009 | 09:57 AM
mouab18c1's Avatar
Default Re: Speedometer not working
im sure its your speed gear inside your tranny...my brothers integra has the same issue
Old Apr 8, 2009 | 04:48 PM
chad's Avatar
Moderator
it can't be that because ecu is not throwing code 17....plus when checked with a multimeter there is out put voltage.
Old Apr 9, 2009 | 06:52 AM
mouab18c1's Avatar
well my brothers CEL will only come on once in a long time throwing code for the VSS. it could be
Old Apr 13, 2009 | 06:43 PM
dpaton's Avatar
Intermittent or dead all the time? If it's dead, it's the VSS, the wire, the cluster, or the connectors. There's nothing else in the circuit. The ECU connection is just looking at the VSS signal, it doesn't influence it in any way.
LurkerS8
Sep 11, 2009 09:45 AM
chad
Apr 7, 2009 03:04 PM
Manolo
10
Jul 12, 2005 03:16 AM
schwanginpt
Jun 28, 2004 08:05 PM
