spark plugs rusted?
Old Jan 6, 2004 | 08:26 AM
SLOW4drINTEG's Avatar
Default spark plugs rusted?
car 1994 integra LS automatic completely stock
one day my sis's stalled all of the sudden while doing about 40mph
so i decided to check all the small things first (sparkplugs/wires/etc)
and the sparkplugs were rusted!!!! i thought it was just old so i got a new set..and i checked it again after about 2 weeks..its starting to get a bit rusty...what is the cause of this? motor has about 140k...time for a rebuild? haha any info would be great
TIA
Old Jan 6, 2004 | 08:53 AM
dip-set's Avatar
Default Re: spark plugs rusted? (SLOW4drINTEG)
might be time for a coolant flush/block flush...
Old Jan 6, 2004 | 10:32 AM
Default Re: spark plugs rusted? (teg-your-it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it &raquo;</TD></TR><TR><TD CLASS="quote">might be time for a coolant flush/block flush...</TD></TR></TABLE>
care to explain what it might have to do with it? thanks!!!
Old Jan 6, 2004 | 11:24 AM
Perfectionist's Avatar
To get rust you obviously need a source of moisture. Normally, the plugs would get hot and dry out any moisture present in the plug tubes. Does she do a lot of short trip driving in high humidity conditions? What brand of plugs did you use?
Old Jan 6, 2004 | 11:49 AM
Default Re: spark plugs rusted? (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">To get rust you obviously need a source of moisture. Normally, the plugs would get hot and dry out any moisture present in the plug tubes. Does she do a lot of short trip driving in high humidity conditions? What brand of plugs did you use?</TD></TR></TABLE>
most of her trips are atlesat 5 miles to about 15 miles (home to school to etc)
yeah i can't figure out what the source of moisture is.
she doesn't drive the car hard at all.
bad rings? just a guess
Old Jan 6, 2004 | 11:50 AM
what if.....the four sparkplug seals (on the valve cover) are bad...so moisture gets in easily? another dumb guess
Old Jan 6, 2004 | 12:45 PM
In most cases those seals leak oil when they're bad. Overall, I wouldn't worry about 'rusty' plugs. There is a whole lot of material there to disintegrate before it would be any sort of problem.
Old Jan 6, 2004 | 10:52 PM
PandaBear's Avatar
Are you talking about rust in "green" color copper rust or just getting white a bit. Copper plug oxidize in part of their normal operations and they will be fine for a long time.
I would check other stuff like distributor cap and rotor, alternator, battery, etc. Check the voltage when the car is idling and it should be 14V or so.
Old Jan 7, 2004 | 11:22 AM
I suppose you should also clarify what part of the plug you are refering to. Is it the upper body, or the electrode end?
white_db8
Jul 25, 2007 04:34 PM
Vtecme92
Apr 23, 2006 07:21 PM
Phatch99
Sep 8, 2005 12:39 PM
petrv
Apr 2, 2005 02:19 PM
SeaBass
Jun 2, 2003 06:16 AM
