Sparco EVO mount problems
Old May 18, 2003 | 06:33 PM
B18EG6's Avatar
Default Sparco EVO mount problems
Hello-
I have a set of Sparco EVO BOTTOM mount seats. The problem I have with these seats is that the bar you pull to move back and foward conflicts with the frame of the seat. When the seat is all the way back, the bar gets stuck in the open position and the seat is free to move back and foward until the teeth engage.
Can I get some nice grade 8 bolts, and some steel or aluminum stock, and raise the seat off of the frame a half inch or so?
pics in a second.... uploading
Old May 18, 2003 | 06:40 PM
B18EG6's Avatar
Default Re: Sparco EVO mount problems (B18EG6)
Pics
I just need to raise it a quarter to half inch....
Here is the bar stuck in the critical position... notice the clearance I need is minimal.
New rails are like 80 bucks or something, and I would have th get side mount ones... Tell me what you think
Old May 18, 2003 | 06:44 PM
bryan305's Avatar
why not just buy some longer bolts, then use washers to increase the space.
Old May 18, 2003 | 07:30 PM
B18EG6's Avatar
Default Re: Sparco EVO mount problems (bryan305)
Washers would work too... just thought strips of metal might be a little better..... might discourage flexing a little better
Old May 18, 2003 | 10:09 PM
Russ713's Avatar
dAng!
Honestly, if it were myself, I would do the longer bolts with good washers or metal squares to raise the seat up.
Old May 18, 2003 | 10:34 PM
B18EG6's Avatar
Default Re: Sparco EVO mount problems (Russ713)
Well yeh either way ima get some longer bolts... you think longer bolts with washers would be just as strong with the metal going all the way down the rail?
thanks
Old May 19, 2003 | 08:13 AM
bryan305's Avatar
The rails are only being supported on the ends...it would be the same if there were washers in there. Don't worry bout the strength of it. Using bars would just add lots of weight, exactly the opposite of what these seats accomplish
*yes, i know they do more than save weight*
K2e2vin
Jun 9, 2008 07:41 AM
RSZero1
Oct 13, 2006 08:09 PM
Race Egr
Welding / Fabrication
11
May 21, 2005 07:32 PM
Want2race
Apr 30, 2003 01:17 PM
Honda318dx
Jan 21, 2002 07:27 PM
