Sounds like fuel won't stop pressurizing?
Old Jun 20, 2006 | 05:21 AM
HackeN's Avatar
Default Sounds like fuel won't stop pressurizing?
I have'nt got the motor running, but I had the key on ignition mode, not on start and I guess I've found the fuel pump is working. I had a leak at the end of the fuel rail by the FPR, and one by where it connects at the firewall.
So I fixed them and when in ignition mode it sounds like fuel is constantly running through the lines? Normally I thought it only goes for about 5 seconds.
Maybe I am hearing something else?
When it was leaking it would go nonstop until I turned off the ignition completely.
I thought maybe it was pouring fuel into the manifold but I opened the TB butterfly and tried to stick my nose in (my face didnt fit :x), and I smelt no fuel whatsoever...
Anyone have any thoughts?
I'm getting desperate to get this damn car running :/ I just need to know if this is normal or not heh
Old Jun 20, 2006 | 05:27 AM
PrettyLude's Avatar
do you have an inline fuel pump hooked up or something? or this is just an intank one? even though its pressuring it the injectors are not opening up, it will not enter the intake manifold?
HondaEF
Jul 19, 2004 06:34 AM
eg6_lsi
Mar 25, 2004 10:29 PM
oneslowcivic
Sep 19, 2003 08:02 PM
1 2 NV
Mar 25, 2003 04:52 AM
integra7
May 27, 2002 06:11 PM
