Something internally???
Old Feb 8, 2004 | 01:10 AM
krazie1's Avatar
BANNED
Default Something internally???
okay my motr only rev's to 5932 rpm
and it sounds like detenation...
won't go passed what can i do
before i just take it to a shop please help with some ideas
even at idle won't go passed this mark
have a pr3 mugen chipped ecu
it is fine no prob used it on another can
this ain't electrical either double checked that...
Old Feb 8, 2004 | 08:20 AM
B18PoweredCivic's Avatar
Default Re: Something internally??? (krazie1)
Check your timing, distributor, spark plugs..Could be misfiring...Give us a more detailed post with your setup...
Old Feb 8, 2004 | 10:00 AM
krazie1's Avatar
BANNED
Default Re: Something internally??? (B18PoweredCivic)
misfiring ain't even the case i got everything coo on that part
well what is it u need to know
upgraded everything basically
Old Feb 8, 2004 | 01:01 PM
sander's Avatar
2.7(p/t)
do you have a check engine light for your vtec oil pressure switch?
-sander
Old Feb 8, 2004 | 01:04 PM
krazie1's Avatar
BANNED
Default Re: Something internally??? (sander)
not even that either....
and i got the vafc so i don't get that light
but as i said that is working if it was hooked up....
Old Feb 8, 2004 | 03:13 PM
sander's Avatar
2.7(p/t)
Thats why
your vafc i bet is wired wrong, check your VTC wire and make sure its in the right place.
-sander
Old Feb 8, 2004 | 03:16 PM
krazie1's Avatar
BANNED
no that ain't it
tried that
i am telling u guys even when i set vtec to 3800 it still doesn't pass 5932
i believe it is something else
what i don't know but it is getting very annoying.....
what is the point of having high reving motor if it doesn't even go to the higher limits
Old Feb 9, 2004 | 08:35 AM
krazie1's Avatar
BANNED
bump
ne one
Old Feb 10, 2004 | 07:07 PM
Try turning off your VAFC and see if it revs up then...Its gotta be something computer controlled....
Old Feb 10, 2004 | 07:12 PM
krazie1's Avatar
BANNED
ur right about this
so does my installer /builder but until tomorrow
when it goes to Bubba for the final touches to awaken this beast
and i hope that is what happens he can make things happen out in the 805!!!
tomorrow should have some answers and final results....
thank you all
Old Feb 11, 2004 | 05:03 PM
krazie1's Avatar
BANNED
well the madass tech at trackmaster's hooked it up
and found it was the vtec screen that was cogged
but i still got other junk to worry about like rings!!!!
again
so oh well i guess i can now go to redline
watch out v8's i am ahunting for y'alll
lol
thank you all so much for the ideas and helpful info
93gsrcoupe
Feb 26, 2005 03:22 PM
Freshazzburu
Feb 14, 2005 06:19 AM
brian2903
Dec 11, 2003 07:20 PM
brian2903
Dec 11, 2003 06:25 PM
ITR 2K
Jan 16, 2002 10:48 PM
