Someone tell me what this wire is for?
It's a tanish (maybe white) wire underneath the dist. It comes out of the harness where the oil pressure wire and vtec wiring is at.
It's a civic cx harness that was wired for vtec. Motor is a built B18C.
Running hondata.
Never noticed it till recently.
My check engine light has been coming on for Overheating, but the temperature gauge isn't getting hot, the car isn't boiling, nothing. I am wondering if this wire has something to do with it.
Running hondata.
The temp gauge and sensors are 2 wires, not one. It mite be for your back up switch on the transmission that lights up your tail light when you put it into reverse.
In the last pic, you can see how it looks like a ground or something was sleeved around it at one time. :confused:
It's very weird that I keep getting the check engine light for overheating, but it's not overheating.
temp gauge is a single wire
have u checked the wiring to the engine temp sensor? its the 2 wire sensor below vtec solenoid
dE.fUsEd
May 18, 2013 12:59 AM
ekim952522000
Jun 11, 2007 11:48 AM
