Some math help (rod/stroke ratio, compression, etc.)
Old Jul 11, 2007 | 08:32 PM
JDMBoostedDA's Avatar
Default Some math help (rod/stroke ratio, compression, etc.)
Ok so I have a GSR block, i have my LS 89mm crank lined up. I'm going to boring my block over to 82mm, possibility of sending it out to be sleeved and bored to 84mm. Im running a B16a head.
Now what I need help with is if I run an LS crank (89mm) whats my rod stroke ratio? I dont know what the rod length is. Im almost certain its the length of the rod divided by the stroke or am i backwards?
And now if i run an LS crank, I would be using LS rods. So, next step is the pistons. I'd like to run all motor. Compression of up to 13.0:1. Whats the best piston for ideal conditions. Now by conditions i mean: Allowing enough valve clearance, the proper compression ratio, etc.
Whats my best bet for this build? Crank, rod, piston combo?
Chugger
Nov 19, 2013 05:33 PM
tundra2000
Sep 28, 2010 06:34 PM
totalimpact
Jun 19, 2006 09:43 AM
LSVTEC_ALLMOTOR
14
Dec 20, 2004 04:59 AM
Spade
Nov 8, 2001 08:15 PM
