solid LSVTEC's
Old Jun 12, 2003 | 12:23 PM
HuskerHybrid's Avatar
Default solid LSVTEC's
anyone been running an lsvtec set-up a while e.g. more than a year? if so how's it doing? Any major set-backs/rebuilds? Is it worth it in your opinion as opposed to slapping a snail on it?
Old Jun 12, 2003 | 01:00 PM
bhive9024's Avatar
Default Re: solid LSVTEC's (HuskerHybrid)
over 2 years over 30,000 miles. Only problem was due to using b16a head studs instead of an ARP, which now are being used. Also if I had to do it over again, I would have done an obd0-obd1 conversion from the get-go.
If there is any one thing I can reccomend it is that if while you are performing this modification you do not have the funds to purchase and install various items (timing belt, water pump, main bearings, every gasket grommet, seal, etcc...) then simply do not do this. As well, if you are not completely capable of this installation or you are not able to pay someone who is, then do not do this.
that is all
Old Jun 12, 2003 | 01:12 PM
g5r's Avatar
g5r
Default Re: solid LSVTEC's (bhive9024)
my friend ls/vtec last a while now, he said the best way to keep it running good is maintaince as in more than normal.
Old Jun 12, 2003 | 01:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bhive9024 &raquo;</TD></TR><TR><TD CLASS="quote">over 2 years over 30,000 miles. Only problem was due to using b16a head studs instead of an ARP, which now are being used. Also if I had to do it over again, I would have done an obd0-obd1 conversion from the get-go.
that is all</TD></TR></TABLE>
luckily, i've been running my ls swap for about 2 years, before dropping in the motor we stripped it down and replaced the water pump, timing belt, all the hoses, gaskets, lines, distributor, plugs wires, seals etc... i've done the regular maintance routines so it's in tip top condition.
how much did it run you in the end? not including the maintenance parts?
Old Jun 13, 2003 | 03:19 AM
irev210's Avatar
i have about 10k miles on my crvtec setup
stock b16 valvetrain stock 2000 crv bottom
itr cams itr intake manafold itr throttle body
basic bolt ons
made 180/128 to the wheels
obd0-obd1 conversion and arp head studs
runs perfect, very happy with it
Old Jun 14, 2003 | 08:09 AM
projecthybrid04's Avatar
Default Re: solid LSVTEC's (g5r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g5r &raquo;</TD></TR><TR><TD CLASS="quote">my friend ls/vtec last a while now, he said the best way to keep it running good is maintaince as in more than normal.</TD></TR></TABLE>
i know lots of people running ls/vtec that have been running for a while, if its done right, it will last, just needs more maintaince than a stock b16
Old Jun 14, 2003 | 03:51 PM
bhive9024's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HuskerHybrid &raquo;</TD></TR><TR><TD CLASS="quote">
how much did it run you in the end? not including the maintenance parts?</TD></TR></TABLE>
I spent 1300 on complete b16a motor and tranny w/ aftermarket JDM LSD and RS&R 4-2-1 header from japan. I sold the b16a block for 200 so essentially it cost me $1100. Excluding not necessary to the swap items, I spent an additional 3-400 in parts, also excluding installation costs
Old Jun 14, 2003 | 09:59 PM
RenoRacing's Avatar
i pieced my first swap togther about a year and a half ago and it ended up being an ls/vtec. i got eveything i needed(motor, tranny, head, ecu) for about 900$ in the end. I made my own mounts and linkage and did the wiring w/ the help of a friend. It was really fast for stock everything minus the F.P.R.
I revved it to 8200k all the time and it lasted for about 9 months including a 1600mile road trip to san diego. then i blew a headgasket and moved on to another motor, then another, then another, and tommorrow i'm throwing it back in the beast and squeezing on it till the next one is built.
ls/vtecs are very fun and just as reliable as any of the parts used to make it up!
InTheLBC20
Mar 27, 2010 04:24 PM
prettylew
26
Jul 27, 2009 01:20 PM
mannydhanju
Jun 6, 2009 05:12 PM
JDMvtecDRAGSTA
Aug 1, 2002 05:19 PM
bigTom
Jul 11, 2001 09:37 AM
