SOHC ZC running really cool??
Old Nov 25, 2007 | 01:24 PM
garageEF's Avatar
Default SOHC ZC running really cool??
ive noticed since i swapped out my D15B1 for an SOHC ZC that it never really gets warm.it takes 10-20 min before i can fel any heat from the heater. the gauge will slowly climb to halfway if the car is sitting but as soon after i start moving it goes back down to the bottom. any ideas on how i would test the temp sender? i have a multimeter.
Modified by garageEF at 7:45 PM 11/25/2007
Old Nov 25, 2007 | 02:48 PM
work_4_honda's Avatar
Default Re: SOHC ZC running really cool?? (garageEF)
It's possible that your thermostat is stuck open. Does it stay cool/cold while driving, with little heat from the vents? Have you felt the radiator hoses after the car has been running for a few?
Old Nov 25, 2007 | 02:49 PM
I'm also assuming that it is full of coolant, and bled properly.
Old Nov 25, 2007 | 06:44 PM
garageEF's Avatar
Default Re: SOHC ZC running really cool?? (work_4_honda)
yes i used the instructions in my haines manual and i am confident that it is properly bled. i dont think its the thermostat because when i open the rad cap the water doesnt flow until it gets warm. i havent felt the hoses but i will in the morning
Old Nov 25, 2007 | 08:07 PM
Tippyman's Avatar
Make sure it's bled really well. Air in the system will make the heat suck.
Old Nov 25, 2007 | 08:37 PM
garageEF's Avatar
Default Re: SOHC ZC running really cool?? (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Make sure it's bled really well. Air in the system will make the heat suck.</TD></TR></TABLE>
i will double check it in the morning
Old Nov 26, 2007 | 05:11 AM
B16B_coupe's Avatar
HRD PKR
make sure there is no small leaks
possible the thermostat is getting stuck
Old Nov 26, 2007 | 04:20 PM
garageEF's Avatar
Default Re: SOHC ZC running really cool?? (B16B_coupe)
well damn wouldnt a leak cause it to overheat?
Old Nov 26, 2007 | 05:01 PM
answerd's Avatar
its most likely ur thermostat cuz i had the same problem exept i got heat but i would go drive 30 miles and the gauge would stay below half engine temp gauge,
i chaged the thermostat and it was then and since fine, to check the thermostat just get it out and boil some water real hot and dump it in and it should open if it dont open all the way or at all theres ur problem, but as i say there are hundreds of possible problems, we can just name the common ones right.
Old Nov 26, 2007 | 05:55 PM
garageEF's Avatar
Default Re: SOHC ZC running really cool?? (answerd)
correct me if im wrong but wont my car OVERheat if the thermostat doesnt open?
when im driving the temp gauge is bottomed out. but when it sits it climbs to a little under halfway like normal. i wouldnt be too worried about it but a cold engine is not as efficient or powerful as it could be
Old Nov 26, 2007 | 07:58 PM
answerd's Avatar
yeah the thermostat blocks the water that goes tothe engine, i dont know how my car got fixed but i guess i got luck, it could still be the stat if the thermostat is always open, jus chge it for a couple bux, nothing hard or major. ok take it out and jus inspect and test it incase it is always open, i dont know im only 15 years old
Old Nov 29, 2007 | 06:11 PM
garageEF's Avatar
fixed. it was the thermostat
Old Nov 30, 2007 | 07:59 PM
answerd's Avatar
haha answerd
loctaz
Aug 21, 2013 07:17 PM
rolledthatho
Feb 8, 2011 02:04 PM
Nooch
Jun 8, 2010 05:25 PM
higgunscrx
Aug 1, 2006 06:34 PM
884door
Apr 23, 2006 08:04 PM
