SOHC Tuning, help w/ ideas.
Old Jan 24, 2003 | 07:50 PM
95si's Avatar
Default SOHC Tuning, help w/ ideas.
welp, im looking to tune a d16z6 to run low 14's usin a 55 shot...
can anyone reccomend me some parts?
im figuring something like this-
d16z6 block and head
p&p head
i/h/e
rods
pistons
zex kit (55 dry)
cam gear
im hoping low 14's with this... anyone care to reccomend some parts.. like what company rods and pistons, what header, what cam gear, etc...
thx!
Old Jan 24, 2003 | 07:53 PM
95si's Avatar
Default Re: SOHC Tuning, help w/ ideas. (95si)
also, would you guys reccomend using the stock intake manifold and throttle body?
Old Jan 24, 2003 | 07:55 PM
sslude's Avatar
thinner head gasket. i heard that nitrous loves high compression
Old Jan 24, 2003 | 08:10 PM
tominos's Avatar
get some high comp. pistons. for use with nitrous, go with forged pistons and rods.
Old Jan 25, 2003 | 02:26 PM
Malgerus's Avatar
Default Re: SOHC Tuning, help w/ ideas. (tominos)
D16Z6 block, Y8 head, Cam, I/H/E + 55 shot should easily net you a low 14 with traction.
Old Jan 25, 2003 | 04:06 PM
asianboi_420's Avatar
u dont need to get forged pistons for 55 shot. a thinner head gasket, head shaved, or high c/r pistons any thing for a little comp. retard your timing a little it runs better with nitrous
Old Jan 25, 2003 | 06:44 PM
kyle h.'s Avatar
Default Re: SOHC Tuning, help w/ ideas. (asianboi_420)
i'd invest in a cam also. not just a gear.
Old Jan 26, 2003 | 06:53 AM
95si's Avatar
Default Re: SOHC Tuning, help w/ ideas. (kyle h.)
what cam would be best for a y8 head?
Old Jan 26, 2003 | 11:52 AM
civicrights's Avatar
93 civic si hb
M/T 22x8x15 slicks
eibach sport line spring from ef
ACT H/D clutch w/ street/strip disk
cold air intake
cam gear
pacesetter header(junk but it was free)
2.25 ex.
b&m fuel pressure riser
field fuel and vtec computer
msd digital 6 ignition
13.6@97mph
1.86 60 ft
with only 10 deg of ignition timing
hope this helps!
Old Jan 26, 2003 | 05:05 PM
kyle h.'s Avatar
not sure about the y8. exospeed has some nice prices for cams.
Old Jan 26, 2003 | 05:19 PM
ExospeedAMcrx's Avatar
we have cam and full valvetrain avail for the y9 a6 and z6
Old Jan 27, 2003 | 12:11 PM
superls92's Avatar
Default Re: SOHC Tuning, help w/ ideas. (exospeedAMcrx)
start with the heads try http://www.gude.com for around 1400.00
you can get your heads port and polished, cams,throttlebody,and manifold,and chip. Oh yeah get a cam gear to retard the timing and let gude know that you will
be running nos. they may change your cam profile and the timing on the chip so your engine won't detonate. Also look at changing you pressure regulator (for the nos) the heads should add around 56 h.p. without nos.
m3kid
Aug 7, 2012 02:49 PM
I_eat_Rice
Sep 21, 2006 09:20 AM
sauceja
May 17, 2006 07:43 PM
green91
Nov 15, 2005 07:07 PM
JdM_Eg_6
96
Apr 13, 2004 05:15 AM
