SOHC Distributor on DOHC?
Old Aug 15, 2002 | 03:23 PM
marklamond's Avatar
Default SOHC Distributor on DOHC?
Hi,
I was wondering if an OBD-1 SOHC distributor can be used on a DOHC? Sorry for the stupid question but from what i see so far the answer is no.
Looking at a D16Z6 TD-42U distributor i have i think the crank sensor is in the wrong alignment with the rest of the sensors for it to work on a DOHC. The crank sensor does not align with one of the teeth on the cyl sensor.
And on a SOHC the camshaft pulley is a different size to the DOHC ones - that must mess things up as the crank pulleys are both the same size?
Thanks,
[Modified by marklamond, 12:29 AM 8/16/2002]
Old Aug 15, 2002 | 03:32 PM
salbaje's Avatar
Default Re: SOHC Distributor on DOHC? (marklamond)
no d series dist are not compatible with b series
Old Aug 15, 2002 | 03:55 PM
marklamond's Avatar
I want to fit a SOHC d series OBD-1 distributor to a DOHC d series along with the SOHC OBD-1 ECU.
At the moment it looks like the position of the engine won't correspond correctly with the distributor's sensors no matter how you look at it.
Old Aug 15, 2002 | 08:32 PM
salbaje's Avatar
dohc d series motor???
Old Aug 15, 2002 | 09:44 PM
raene's Avatar
Default Re: SOHC Distributor on DOHC? (salbaje)
It's probably a ZC
Old Aug 15, 2002 | 10:51 PM
nikitad's Avatar
Yeah, if you would have meant the Dohc D16a8/D16A9, then you could use the D16A6 distributor. (all motors are OBD-0) You'd have to repin the distro plug and do something about the fitment - all three boltholes wouldn't line up. You'd need to use just 2 of them and possibly widen the holes on the distributor, so they alighn.
Now, I doubt any of american people will give you a piece of mind with an OBD-1 DOHC D-series, it's even more rare here than a ZC (=D16A8 OBD-0).
But coming from the abovementioned analogy, you may have a chance using a sohc distro on the dohc engine. Just expect to have to do modifications.
My guess.
Yeah, and let us know how it went.
Old Aug 16, 2002 | 09:28 AM
Ek-CoolGuy's Avatar
You can swap the internals of the distributors. My cousin did this but i dont quite remember how. His sn on aim and ht is b20zvtec.
edit: his sn is b20zvtecEK
[Modified by Ek-CoolGuy, 6:35 PM 8/16/2002]
crxsleeper210
Jan 8, 2007 09:01 AM
al3e
Jun 9, 2005 07:51 AM
project civic
Mar 13, 2005 03:52 PM
KevronsEG
Oct 16, 2003 07:33 AM
Ltech
Feb 5, 2003 08:14 PM
