Smog Failed..94 EG SI,NEED HELP!!!
Just bought my fourth CIVIC and it's been a EFFIN NIGHTMARE!! burns too much oil to pass CA SMOG.. Do i need new valves? If you have an idea of what it might be please send me an idea of how to cure it THX!!!!
how do you know he needs valves? what if it needs rings. Also burning oil doesn't not register on the 5gas analyzer. But it does clog the cat and makes it harder or impossible to store oxygen.
If you post the readings than we can verify whaty you need
I dunno. He asked if he needed new valves and with all of the info he provided(*none*) I figured it was as good an answer as any. Sarcasm is sometimes hard to get across on the internetz....
Sorry bout that, DAMN WORK!!, interferes with REAL LIFE!! haha... but i really appreciate the responses. here's the readings..IDLE EMISSION TEST RESULT -
HC (PPM) MEASURED -400
MAX -100
RESULTS- GROSS POLLUTER FAIL.
THE ENGINE - D16Z6 W/DC 4TO1 HEADS, AEM INTAKE, SKUNK2 EXUAST, NO LEAKS, NO SMOKE, RUNS STRONG? 155K.... THX
MAX -100
MAX -100
MAX -100
wdissident
Feb 26, 2009 05:13 PM
