Slim Fan Installation
Anyone ever installed one on a civic? i cant find a good solid way to mount it... its a 12" proform fan. i guess i may have to fabricate a bracket, but i wanted to see if anyone had suggestions.
Go to your local auto parts store. Buy a transmission cooler mount kit. They are less than $10. They are just zipties with ends on them that go through the radiator fins.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">Go to your local auto parts store. Buy a transmission cooler mount kit. They are less than $10. They are just zipties with ends on them that go through the radiator fins.
wow..never seen those..how do they work!?
</TD></TR></TABLE>wow..never seen those..how do they work!?
I just installed one in my hb on tuesday.
use what dwnthehatch posted, they work well.
I also had to install a higher rated fuse. It kept blowing the 15 amp fuse. I replaced it with a 25amp fuse and so far it has been working fine.
I used these straps above with my 14" Hayden fan purchased at Kragens for $59.99. As you can see I mounted the fan infront of the stock GSR radiator to gain more space for my H22. Bugs and other debris from the road may be an issue if the car is driven often with it mounted in front like mine.
</TD></TR></TABLE>I used these straps above with my 14" Hayden fan purchased at Kragens for $59.99. As you can see I mounted the fan infront of the stock GSR radiator to gain more space for my H22. Bugs and other debris from the road may be an issue if the car is driven often with it mounted in front like mine.
Team Bukkake Sucks!!!
Aug 22, 2005 04:31 PM
