slight rattle from 3.5K-4Krpm???
I wouldn't doubt that this is a common problem amoung integras-- I have this problem on my 94 GSR and my friend just had it start happening to him on his 98LS... I don't think it's the heat shield because it doesn't rattle extremely loud, and it only rattles between 3500 and 4000 RPM. Anyway, I was hoping someone would be able to tell me what the f*** is making this noise... do I need to replace the catalytic converter entirely??? is it something wrong with the header??? possibly the heat shield on the header??? I know that's not the problem with mine-- because I took that heatshield off and still have the problem... let me know what you guys think.
Thanks in Advance.
Zack
Thanks in Advance.
Zack
Has the head ever been of the block?
When I pulled my head I didnt reinstall the 2 bolts for the intake manifold support when I re-installed it. Now it makes a slight rattling noise at certain rpms and engine loads.
Just 1 thing to check off the list to narrow things down. goodluck.
Another one that would cause noise to come kinda from that area would be if you had a short shifter installed but yu wouyld be able to feel that.
1 more thing to probably check is where the header bracket mounts to the bottom/back of the block.
