sleeved b18a bore question
Old Feb 23, 2004 | 10:39 AM
fearless_dsm's Avatar
Default sleeved b18a bore question
i picked up a used b18a block for $50 that had aftermarket sleeves and a "solid deck"...its bored to 81.5-82mm(my caliper is a little off)..i do not know what brand the sleeves are but it looks like a custom block gaurd was welded in because the water holes were made with a drill bit...the sleeves are approx. 89mm total diameter...heres my problem...theres 4 vertical 1 inch long gouges in the #2 sleeve about half way down and about .5mm-1mm depth...2 on each side of the sleeve...i was told that someone installed the locks for the wrist pin wrong and thats where the notches came from...im going to be using the block for all motor purposes so i want an 85mm bore which would take care of the notches in the sleeve but im not sure if i can bore out the sleeve that much...there looks to be enough space...and they have about the same specs as darton replacement sleeves...ill post pics if i can....lemme know what you think..thanx
Old Feb 23, 2004 | 11:47 AM
Building_rice's Avatar
Default Re: sleeved b18a bore question (fearless_dsm)
As long as the sleeves butt together the sleeves would allow for an 85mm bore, pending 1 very important thing....the profile of the sleeve below the deck. Darton used a groove in the flats on their newer sleeves (bad idea in my opinion, but anyways). The purpose of this must've been for coolant but it also lowered the wall thickness resulting in a sleeve that couldn't be bored as large. More than likely the sleeves go straight down, but I don't know anything about the sleeves you have so I couldn't really tell you. If they're staight then 85mm is not a problem.
Old Feb 23, 2004 | 03:23 PM
Default Re: sleeved b18a bore question (Building_rice)
thanx...they go straight down and are the same thickness at the top and bottom...
Old Feb 23, 2004 | 03:33 PM
warwagon's Avatar
50 dollars sleeved block damn thats pretty cheap
Old Feb 24, 2004 | 01:20 AM
Default Re: (warwagon)
yea,it came with a good LS crank too...the guy was closing his shop down and we went rummaging through all his stuff and bought another complete LS motor for $100 and a good jdm b16a block with crank for $100 and a few other things so he let the sleeved block go for cheap....any other input??
Old Feb 24, 2004 | 07:18 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fearless_dsm &raquo;</TD></TR><TR><TD CLASS="quote">i picked up a used b18a block for $50 that had aftermarket sleeves and a "solid deck"...its bored to 81.5-82mm(my caliper is a little off)..i do not know what brand the sleeves are but it looks like a custom block gaurd was welded in because the water holes were made with a drill bit...the sleeves are approx. 89mm total diameter...heres my problem...theres 4 vertical 1 inch long gouges in the #2 sleeve about half way down and about .5mm-1mm depth...2 on each side of the sleeve...i was told that someone installed the locks for the wrist pin wrong and thats where the notches came from...im going to be using the block for all motor purposes so i want an 85mm bore which would take care of the notches in the sleeve but im not sure if i can bore out the sleeve that much...there looks to be enough space...and they have about the same specs as darton replacement sleeves...ill post pics if i can....lemme know what you think..thanx</TD></TR></TABLE>
If its sleeved, then it should be ok to bore since the aftermarket sleeves are usually a lot thicker than stock.
But then you say it has a block guard welded into place? If someone sleeved their block i dont think they would put a block guard in there...
Anyways if the sleeves are like darton as you say its ok.But if its stock with a block guard then no
Old Feb 24, 2004 | 07:19 AM
ExospeedAMcrx's Avatar
Default Re: (fearless_dsm)
take some pictures so we have a better idea on what you are workin with.
Wil
Old Feb 24, 2004 | 08:47 AM
Default Re: (exospeedAMcrx)
ill get some pics asap....its not just stock with a welded in block gaurd...the sleeves are about 89mm total diameter...and the thickness is about 3.5mm-4mm....i have no other way to explain what is welded in other than custom blockgaurd...picture a block w/ darton open deck sleeves...than picture it with a complete solid deck ...than picture the deck with water holes drilled w/a drill bit...anyways ill put up some pics...thanx
12secdc2
Dec 4, 2008 09:25 PM
92VXeg
Nov 21, 2008 10:28 AM
Death_to_Thieves
Nov 25, 2004 07:51 PM
fearless_dsm
Feb 24, 2004 08:48 AM
satan_srv
Mar 19, 2003 01:52 PM
