skunks2 or ground controls on civic setup with stock shock.....question
Old Jan 22, 2002 | 09:45 PM
hobo79's Avatar
New User
Default skunks2 or ground controls on civic setup with stock shock.....question
if i get skunk2 or ground control coilovers for my civic coupe......and i dont drop it or possibly very little, will my stock shocks still be ok? as if it were to have the stock springs on?
Old Jan 22, 2002 | 10:45 PM
Chicken SOup's Avatar
Default Re: skunks2 or ground controls on civic setup with stock shock.....question (hobo79)
Most likely when u get coils you'll find urself dropping it more than u thought..
Well atleast thats wut happened to me
To be safe i would reccomend getting some aftermarket shocks,, Stock can only absorb so much and it will only be a matter of time b4 u blow them out...
Old Jan 22, 2002 | 11:31 PM
Kamin's Avatar
Default Re: skunks2 or ground controls on civic setup with stock shock.....question (Chicken SOup)
yes
do not run stock shocks on coilovers
if your gonna do it, do it right
save up some $ and get a good set of shocks
koni yellows for GC's are good. but not cheap.
Old Jan 23, 2002 | 08:40 AM
MaddMatt's Avatar
Default Re: skunks2 or ground controls on civic setup with stock shock.....question (KAMiN)
Stock shocks cannot control the stiff springs. You will look rediculous bouncing all over the place. You may not be on the bumpstops, but at least you'll look like you are.
Old Jan 23, 2002 | 07:05 PM
hobo79's Avatar
New User
Default Re: skunks2 or ground controls on civic setup with stock shock.....question (Lil Cs Zc)
where can i go about getting koni yellows, any sites? cant find any. also, when you guys say bottoming out and blowing my shocks, what actually happens when that happens? just curious. also, do i need to keep my bump stops after i get the shocks and coilovers?
Old Jan 23, 2002 | 07:43 PM
MaddMatt's Avatar
You damage the internal components (valves and stuff).
Old Jan 23, 2002 | 08:02 PM
hondacivic4g's Avatar
Here are a few companies that carry Koni (yellows) shocks- http://www.optauto.com http://www.ardperformance.com http://www.importparts.com
Hope this helps!
Later-HC4G
Old Jan 23, 2002 | 10:37 PM
hobo79's Avatar
New User
Default Re: skunks2 or ground controls on civic setup with stock shock.....question (hondacivic4g)
can i be able to just get some ground control coils and once they go, install some aftermarket shocks like KYB, Tokico, or Konis then?
Old Jan 23, 2002 | 10:38 PM
hobo79's Avatar
New User
also, is there much of a diff if i get gc, skunks versus maxspeed, apc, arospeed coils? other than price
ady2glude707
Suspension & Brakes
24
Nov 6, 2012 07:50 PM
ady2glude707
Dec 14, 2011 03:27 PM
hialeahzbg
Nov 19, 2009 12:25 PM
stock99
Sep 23, 2004 06:56 AM
paulyman
Jun 10, 2002 10:27 PM
