skunk2 manifold install HELP!!
Old Mar 14, 2005 | 05:56 PM
LilCivic04's Avatar
Default skunk2 manifold install HELP!!
i put my skunk2 manifold on and i noticed that when i put the throttle cable bracket on, the throttle cable was WAY to short. how do i deal with this? and i also nice that right next to the throttle body, the fuel line if right in front of it. what do i do what that too?
Old Mar 14, 2005 | 08:42 PM
turtle-eg's Avatar
Default Re: skunk2 manifold install HELP!! (LilCivic04)
What engine do you have? also what year?
Old Mar 15, 2005 | 12:23 AM
LilCivic04's Avatar
z6 in an eg6
Old Mar 15, 2005 | 05:18 AM
CompressionFed's Avatar
hmmm, Ive never had a problem with a skunk2 manifold in an EG. Depending on how short it is, you should be able to fabricate a new throttle cable bracket. Just find some metel, make some measurements, cut the two holes, bend it to the correct position and you should be fine.
This same thing happens when swapping a GSR manifold to a skunk, or edelbrock, etc., but in that case, the cable is too long. Try out your fabrication skills and create the solution
Drzhope89
May 17, 2017 12:09 PM
Mr.Bakedgoods
Aug 23, 2011 07:50 PM
ganjasnack
May 31, 2009 02:41 PM
TABIAS
Jan 13, 2004 08:06 PM
