Skunk2 cams, or gsr block??
I got a stock b16a in my eg right now and wanna pump up some power. Should i go for the gsr block or get the cams? its a daily driver and i wanna go NA application, is the block worth getting?later on i will eventually get cams anyways. but dont know if i whould invest in a block
Definately get the gsr block. It will make a world of difference in everyday driving where as the cam's will only give you power up higher. Using your b16 or ctr/itr pistons will give you much better compression than the stock gsr ones.
evildc2
12
May 20, 2008 08:13 AM
