skunk stage 2 or 3's
Old Mar 15, 2003 | 09:20 PM
warwagon's Avatar
Default skunk stage 2 or 3's
i hear that the stage 3's need at least 12.5-1cr but does anyone know if 12-1cr on a 84.5mm block would be enough to use these or would one be better off running the stage 2's.
also how hard are either one of these to tune
Old Mar 15, 2003 | 10:53 PM
DA MUGEN 1's Avatar
Default Re: skunk stage 2 or 3's (warwagon)
Is this for a street car or drag car?
Old Mar 15, 2003 | 11:42 PM
sgT's Avatar
sgT
stage 3s are quite capable of destroying an engine very easily.
be very careful if you plan to use them
Old Mar 16, 2003 | 03:16 AM
BoM's Avatar
BoM
Default Re: skunk stage 2 or 3's (sgT)
stage 2 is suppose to be close to JUN3's profiles
so i'd expect stage 3 to be veryyyy high lift....
Old Mar 16, 2003 | 03:52 AM
J2turbo21's Avatar
Default Re: skunk stage 2 or 3's (DA MUGEN 1)
which one is it?
Old Mar 16, 2003 | 06:04 AM
Neukin's Avatar
Default Re: skunk stage 2 or 3's (J2turbo21)
id use the stage 1 wait i have a pair of those for sale buy them
Old Mar 16, 2003 | 06:56 AM
b19coupe's Avatar
Just curious-sounds like you are referring to something you have seen or experienced. What happened ? Did somebody put some stage 3's in a motor without claying?
By the way, the Stage 2's run fine with a minimum of tuning. Idle is almost like stock, only a very slight lope. Most people would not be able to tell.
[Modified by b19coupe, 7:58 AM 3/16/2003]
Old Mar 16, 2003 | 10:45 AM
warwagon's Avatar
weekend driver, i plan on claying the head and taking all precautions before installing them, i already have the skunk 2 valvetrain and gears, just waiting for my mind to make itself up
hows the tuning on the 3's
Old Mar 16, 2003 | 10:48 AM
warwagon's Avatar
Default Re: skunk stage 2 or 3's (b19coupe)
hey b19coupe what kind of #'s are you laying down with the setup you have in your sig.
Old Mar 16, 2003 | 11:17 AM
b19coupe's Avatar
200/140 last time I dynoed. Lots of room for improvement. Just put the RC's on there and instead of waiting to finish my other motor, I stuck the Portflow head on this block. I am going to dyno later this week, hopefully I will see some improvement. If all goes well, will take the car to Fontana next weekend.
Old Mar 16, 2003 | 11:37 AM
RenoRacing's Avatar
are you people talking from experience or just hear say. My friend evilxkid has had the stage 3's in his car for about 6 months now, it's a b16 w/ springs, retainers, and now it has ITB's, it frequently revs to 10k rpms and does fine daily driving. The block has never been touched the head hasn't even been pulled off of it ever! It's got the stock headgasked from japan! I don't understand why people think that cams can simply blow your motor up???
Old Mar 16, 2003 | 11:59 AM
warwagon's Avatar
Default Re: skunk stage 2 or 3's (HavokRacing)
stage 3's with a stock bottom end, how is he doing that without high compression
Old Mar 16, 2003 | 02:58 PM
HellSol's Avatar
i have the 2's and they pull just fine, noo need for 3's unless you have hella compression
-steve
Old Mar 16, 2003 | 03:57 PM
reese's Avatar
Default Re: skunk stage 2 or 3's (HellSol)
how much hp is the stock block b16 making with the stage 3s?
Old Mar 16, 2003 | 05:07 PM
warwagon's Avatar
on the springs i recieved they are brand new in the box and have no markings but they are in seperate bags (intake and exhaust i suppose????) how do i tell them apart or are they different
also which way is up and down, the retainers fit tighter one way but still no marking or whatever.
10000rpm
Oct 30, 2004 04:27 PM
ramz7887
May 30, 2003 01:24 PM
SymphonyX
Mar 26, 2003 09:26 PM
lucas569
Dec 1, 2002 11:12 PM
