Skipping IACV?
Old Jun 26, 2002 | 12:45 PM
Spade's Avatar
Default Skipping IACV?
If I leave the damn thing plugged in and just put a piece of aluminum between it and the Intake Manifold.
Attempting to get rid of the stupid thing and deal with my idle issues.
P.S. I am gonna try it tonight anyway just want some opinions.
Old Jun 26, 2002 | 02:39 PM
Spade's Avatar
Default Re: Skipping IACV? (Spade)
No ideas?
Old Jun 26, 2002 | 03:15 PM
tinkerbell's Avatar
i dont think runing without an IACV bypassing air to the engine will help your idle.
unless it is broken.
(i dont know what the history of your idle problems are though...)
HTH,
t..
Old Jun 26, 2002 | 04:48 PM
builthatch's Avatar
MiG-21 superfan
you will have no idle control and the cold idle will be non existent, if you have timing and fueling piggybacks, you can compensate and atleast get it to idle like me. i lean it alot and advance the timing @ position 1 on my ITC...
Old Jun 26, 2002 | 07:46 PM
Spade's Avatar
Default Re: Skipping IACV? (builthatch)
Well.....it worked.....ROFL.
Before I couldn't get my idle to drop below 1100 and the idle would be at a high 2000 while cruising to a stop. Now.....750 on the nose.
I am pumped this is the first time I have gotten the idle normal on this car.
I guess the IACV is bad.......eh, oh well it isn't throwing a code so it can stay. I don't care about the fast idle for warm up anyway.
Old Jun 27, 2002 | 06:27 AM
Spade's Avatar
TTT.......60 miles already and I love it.
Old Jun 27, 2002 | 07:29 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
but does your idle adjust for engine temp?
that's a big point... it'll warm up the car faster...
why can't you connect it to your intake/airbox?
Old Jun 28, 2002 | 07:43 AM
Spade's Avatar
Default Re: Skipping IACV? (dLo GSR)
It bypasses air past the Trottle body. So there is no point in connecting it to the intake box.
Yes I lost the warm up......oh Darn (sarcasm), so I have to put my foot on the pedal for a few minutes before I leave.
At least now I don't have a cruising idle of 2000 and a stopped idle of 1500.
That is why I bypassed it......instead of replacing the IACV (money issue) I simply took it out of the picture.
Old Jun 28, 2002 | 08:51 AM
Chubz's Avatar
I have a bad IACV circuit (probably the ECU) I bypassed it a while ago, when it was cold out the car would not idle unless i held the rpms at 1500 rpms for a few minutes until it gradually warmed up and idled fine.
Old Jun 28, 2002 | 09:13 AM
Crazydave's Avatar
Default Re: Skipping IACV? (SuperTech)
Yeah.. but its' not that bad living in southern california...
Old Jun 28, 2002 | 10:05 AM
Spade's Avatar
Default Re: Skipping IACV? (Crazydave)
Exactly, I really don't bother.....she idles at 450 when cold and then moves up to 1000 when warm.......
Still researching that......actually going to reset the TPS and trottle stop but, gotta switch suspensions first.
Old Jun 28, 2002 | 10:43 AM
you've probably alreay covered this but did you play with your TPS to try and fix the idle? or the screw-bar under the butterfly valve spring?
Old Jun 28, 2002 | 11:34 AM
Spade's Avatar
nope.......was going to do that tonight but I have to trade the spings from one Civic to the other to get the full trade in value of the one with a "modified suspension".
If I get that done tonight then I will play with trottle tomorrow afternoon.
Old Jun 28, 2002 | 12:07 PM
supergreenNA1's Avatar
New User
yup... i did the same thing except i used a plastic coated playing card (jack of clubs if u must know.) all my idle problems went away except for the warm up issue.
Old Jun 28, 2002 | 12:14 PM
Spade's Avatar
Default Re: Skipping IACV? (supergreenSol)
HTF do you mention his name in my tread!!!!
ROFL.
Old Jun 29, 2002 | 11:27 AM
so did you try the TPS yet?
Old Jul 1, 2002 | 10:49 AM
Spade's Avatar
Nope, Took me all weekend to Move from one appartment to the other swap the suspension and work.......my weekend sucked a fat one.
And I cannot do it tonight either........SIGH, I will post a new tread once I get a chance to get at the TPS.
JSR
May 17, 2006 10:27 PM
ex94vtec
14
May 6, 2006 02:07 AM
Civic Racer X 7
Jul 23, 2003 07:19 AM
Pele
Feb 9, 2003 01:01 AM
