Shifting into Gears very hard.. help
Old Feb 14, 2004 | 02:04 PM
Incubus05's Avatar
Default Shifting into Gears very hard.. help
I encountered this problem about a week ago, and prior to that shifting into any gear was easy. and now it is very hard to put into any gear whatsoever. Could it be that the Sencros (spelling) are off. I had already went under the car to check to see if anything was caught in the shift linkage, but nothing was in the way.
Old Feb 14, 2004 | 02:54 PM
Chiovnidca's Avatar
Default Re: Shifting into Gears very hard.. help (Incubus05)
Does it do it all the time or only when the engine is running?
Old Feb 14, 2004 | 03:45 PM
func-tion's Avatar
Do you have alot of "dead" travel in your clutch pedal.
Do you have a cable tranny? Maby the cable needs to be adjusted.
If you have a hydro tranny, You may have to bleed the line.
Old Feb 14, 2004 | 07:29 PM
Mohudsolo's Avatar
Default Re: Shifting into Gears very hard.. help (func-tion)
Clutch is not disengaging properly. Bad hydraulics or old nasty fluid, misadjusted or bad cable. Possible bad pressure plate. If it was just one gear, could be the trans, all of them is the clutch. All answers assume the car was not in an accident in the last week, of course.
justindenton
Classic Hondas
Aug 29, 2010 07:41 AM
bradennicely
Apr 15, 2010 04:59 PM
blue89hatch
Nov 19, 2008 09:05 AM
hotsuma23
Sep 7, 2008 08:16 PM
ED6JDM
Jun 14, 2007 01:27 PM
