Shifter Bushings: Disappointing
Old Feb 3, 2003 | 07:36 PM
mr_mbuna's Avatar
Default Shifter Bushings: Disappointing
I had a shop install some Energy Suspension shifter bushings into my 95 Integra LS a few weeks ago... and I've got to say, I'm very disappointed. I didn't notice any difference at all over the stock shifter bushings. There is still about 1/4" horizontal play in the shift **** while in gear.
Why did I never hear anyone else disappointed with their bushings? Could it be that maybe the shop that was supposed to install them didn't actually install them? Or if installed improperly, would they be "worthless" over the stock bushings?
Ben
Old Feb 3, 2003 | 07:52 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Shifter Bushings: Disappointing (mr_mbuna)
check for play in the pin that connects your linkage to the transmission. mine was shot and i eventually could not put it into any outside gears, first, fifth or reverse.
after the replacement and bushings i decided i didn't need the short shifter after all, that's how well it worked. no play in gears at all.
stan
Old Feb 3, 2003 | 11:01 PM
Airbag Club's Avatar
Default Re: Shifter Bushings: Disappointing (90crxsi)
wow, i noticed a big difference when i installed my energy susp. shifter bushings....the shifter goes into gear a lot smoother, and there was a lot less "play." you should take a look under your car and see if they really did install the bushings, unless it is a reputable shop that you trust....IMO some shops can be kinda shady...
The_Honda_Guy
16
Nov 28, 2009 06:09 PM
x_tuh_sy
Dec 8, 2007 12:03 PM
turbotime
May 4, 2006 10:15 PM
jromulo
Jun 2, 2005 12:43 PM
MrSmith
Aug 7, 2001 07:39 AM
