Shift Linkage Help For CRVTEC Into 87 CRX Si?
Old Jan 5, 2002 | 08:59 PM
Red Civic T's Avatar
New User
Default Shift Linkage Help For CRVTEC Into 87 CRX Si?
I know HASport has a premade one, but what would be an easy, effective (and cheaper) way to do it?
For those of you who have not figured out, such a swap ends up being kind of expensive if you want to "dot the I's and X the T's"....
Old Jan 6, 2002 | 12:07 AM
Gasoline Fumes's Avatar
Default Re: Shift Linkage Help For CRVTEC Into 87 CRX Si? (Red Civic T)
I think you just need to change the length of the two rods. According to SCC's article on putting the B16 in an '86 CRX (11/01), the shift rod needs to be 0.25" longer and the torque rod 0.5". Apparently you use '86-'89 Integra rods, not Civic/CRX rods.
Old Jan 6, 2002 | 08:43 AM
New User
Default Re: Shift Linkage Help For CRVTEC Into 87 CRX Si? (Gasoline Fumes)
Yea, seem to recall that....gonna check out if my "metal man" can hook that up for me...
Old Jan 6, 2002 | 07:54 PM
brian g's Avatar
Default Re: Modifying Shift Linkage in CRX Si for B-series...
You can also modify the CRX linkage. The article only mentions the Integra linkage, because that is what we sell, lengthened NEW Integra linkage.
The CRX linkage just needs to be lengthened more, it works just as well.
brian g
streetsold6teeny8
18
Jun 29, 2009 10:18 PM
CRX_GUY_123
14
Apr 5, 2004 09:13 AM
IntegD
Jul 23, 2002 10:01 PM
See Are X
May 18, 2002 12:13 PM
