shaved head=HP
Old May 23, 2003 | 11:34 AM
migo's Avatar
New User
Default shaved head=HP
If I have 11.0:1 CR piston, how much should I shaved off the block to get to 12.0:1 Cr
Old May 23, 2003 | 12:56 PM
martini's Avatar
Default Re: shaved head=HP (D.SPECS)
you'd never be able to shave that much off without knocking your valves. unless maybe you got new cams that had about half the lift of stockers..but in that case, you wouldn't see any increase in hp.
to make a jump in compression like that, try new pistons, or overbore, or skunk2 flat bottom valves or something like that.
Old May 23, 2003 | 02:47 PM
1_bad_EF's Avatar
.030" if it hasnt been shaved already
Old May 23, 2003 | 03:03 PM
Blaze45's Avatar
Brrraaaap!
Default Re: shaved head=HP (1_bad_EF)
when you start shaving alot off you have timiming belt fitment issues...
Blaze
Old May 23, 2003 | 03:45 PM
dfoxengr's Avatar
Default Re: shaved head=HP (Blaze45)
u mean milling.
Old May 23, 2003 | 03:46 PM
dfoxengr's Avatar
or if its the block then decking...
Old May 23, 2003 | 05:03 PM
migo's Avatar
New User
Default Re: shaved head=HP (hybridvteceg)
I'm close to .040 and I'm running on 11.0:1 pistons, No valves problem here, just a little detonation at first, but I tuned it out
Yannx13
Sep 21, 2012 06:25 PM
phirewire
Jun 28, 2011 12:28 PM
teg_racer
19
Feb 28, 2011 08:43 PM
baonest1
May 15, 2003 09:43 AM
