servicng rear brakes
Old Jan 25, 2007 | 04:59 PM
jimjonez
Guest
Posts: n/a
Default servicng rear brakes
ok guys, once again i'm in desperate need of YOUR help. this weekend i plan on changing or servicing the rear brakes on my 1990 honoda accord dx auto tranny, becuase they've been squeaking for about two weeks so i want to take a look at them. problem is i have never done anything to my rear brakes and don't know where to start. any body have any type of info with pictures on how i could do this project myself????
please
Old Jan 25, 2007 | 05:28 PM
Fezzie's Avatar
Default Re: servicng rear brakes (jimjonez)
ok i dunt have any pics but ill tell you what i do on my 90 civic
i dunt know if you have disk or drum but heres some help for drums
1.take off the tire. lol
1a. take off drum an take it to get them turned
2. remove all the springs but make sure you remember what order you took them off in
3. take off the pads
4. put on new ones and put springs back on in reverse order you took them off
thats not much of an explanation but thats it
Old Jan 26, 2007 | 09:08 PM
frostyrb's Avatar
Default Re: servicng rear brakes (fezzie)
Also if you have to change the shoes do one side at a time in case you forget where a spring or whichway the self adjuster goes. If they need to be serviced then you want remove the drums & wipe them out with a fresh clean rag. Then you want to get a can of brake clean & spray down the shoes, backing plate, all. Then blow off with compressed air, & get a piece of 80 grit sand paper & sand the glaze off the shoes. Then blow off shoes again with compressed air & adjust out self adjuster to where the drum has a slight bit of drag against the shoe. Then your done. Put the wheels back on and drive away.
Old Jan 27, 2007 | 08:06 AM
Centripital's Avatar
The spring tool for drum brakes makes it easier....i'd recommend at least getting a haynes manual and asking more specific questions if you need them.
Old Jan 27, 2007 | 07:35 PM
Muckman's Avatar
Moderator in Chief
I replaced the shoes on a probe and it was hard as hell to get the shoes perfectly centered to allow the drum to fit over. I dont know if all drums are the same but Im sure its similar. Was it because I reused the drums and didnt get them turned?
cautrell05
Suspension & Brakes
11
Mar 5, 2009 08:58 AM
TN90accord
Jan 21, 2008 10:31 AM
jimjonez
Jan 25, 2007 06:02 PM
loki2323
Dec 30, 2002 11:57 AM
integra*RS*
May 20, 2002 10:03 PM
