Sensor inputs for vtec activation?
for vtec to activate these sensor inputs must be present?
vss
cts
rpm
map
is that it?
does anyone know the specifications like min voltages required?
how many volts does the ecu send out to the solenoid to activate vtec, 12volts?
vss
cts
rpm
map
is that it?
You mean ECT right... engine coolant temperature... I'm pretty sure it doesn't look for MAP vac... yes you're right on VSS, RPM, VTEC press... Not sure about the direct voltages tho... Latez
kaboom954
Feb 25, 2010 03:23 PM
vtec@4000rpm
Engine Management and Tuning
Jan 31, 2009 02:17 PM
Neutex22
Feb 2, 2005 09:25 AM
