secondary fuel injectors ?
Old Sep 4, 2007 | 10:33 PM
rsdriver17's Avatar
Default secondary fuel injectors ?
iv been looking at intake manifolds and the edelbrock has the one manifold with the secondary fuel injector ports. I was wondering how that set up works, such as splicing the fuel to both rails and the computer setup is it worth the trouble?
Old Sep 4, 2007 | 11:01 PM
doood's Avatar
been there done that
Default Re: secondary fuel injectors ? (rsdriver17)
instead of using both sets of injectors, some people opt to block off the main injector location and use the secondary one only for a cleaner look.
Old Sep 5, 2007 | 08:17 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: secondary fuel injectors ? (doood)
the other bungs are there for 2 reasons.
people running alcohol, because 1 set of 1600's isnt enough,
or people that use 2 sets of smaller injectors instead of 1 set of large ones.
to get fuel to both rails, you would come off of the pump with like a -10, split it with a y to 2 -8's, feed each rail with the -8's, off of the rail with -8's to each side of the reg, then the center port of the reg back to the tank.
Old Sep 5, 2007 | 11:51 AM
rsdriver17's Avatar
Default Re: secondary fuel injectors ? (boostedcivicsir)
alright what about wiring the second set of them can u splice off the main ones, i was told or heard u need a separate system of some kind
Old Sep 5, 2007 | 12:01 PM
Mr. Badwrench
you need an ems with 4 more injector outputs to do it right.
Old Sep 5, 2007 | 12:54 PM
rsdriver17's Avatar
who makes the ems ?
Old Sep 5, 2007 | 05:16 PM
Mr. Badwrench
aem can do up to 10 channel i think, all the other real stand alones that DONT use a honda ecu can. motec, f.a.s.t. dfi, big stuff, electromotive, most of them can atleast do 8 channels.
Pumpking.
Jun 21, 2016 12:58 AM
mc_yen
Jun 11, 2008 08:00 AM
tony413
Aug 29, 2007 12:19 PM
e jay one
Mar 26, 2007 03:58 PM
baonest
Aug 5, 2001 02:51 PM
