secondary 02 sensor removal
Old Jun 14, 2003 | 08:33 AM
Hunter's Avatar
Default secondary 02 sensor removal
here's the deal... i'm runnin' a PR3 ecu on my 1st gen b16. i recently had a custom chip made that removed the speed limiter and secondary 02 sensor.
here's my problem... today, i threw a code 2... which is the secondary 02 sensor. i cut the wire running to the 2nd 02, and removed the sensor completely. the wire is still connected to the ecu and is just chillin' there. i'm thinkin' that the chip is faulty and doesn't remove the sensor. or, do i have to leave the 2nd 02 sensor connected for some reason?
thanks,
Hunter
Old Jun 15, 2003 | 08:11 AM
Hunter's Avatar
Default Re: secondary 02 sensor removal (Hunter)
bump, bump it up
Old Jun 15, 2003 | 02:37 PM
Patch's Avatar
I would think that if the ECU is programmed not to look for a 2nd O2 sensor, then it doesn't matter if its connected or not.
Bump for a guy who has no idea whats hes doing
Old Jun 15, 2003 | 03:50 PM
Hunter's Avatar
Default Re: secondary 02 sensor removal (CRX PAT)
1SickHb
Nov 10, 2005 01:04 PM
maximedx
Mar 24, 2005 04:46 PM
eL
Jun 12, 2003 01:53 PM
