Sea Foam
Old Mar 3, 2006 | 08:01 PM
crazydragonclk's Avatar
Default Sea Foam
I* justpicked up a bottle of sea foam and I dont know how to apply it into the brake line, is it okay to put half in the engine and half in the fuel tank?
the guys at the store said I should put 1/3 in gas tank engine and brake line. but I dont know how to get to the brake line and I dont really trust myself on that.
Old Mar 3, 2006 | 11:56 PM
.xcalibur.'s Avatar
Its not really the brake line. He meant to say the Brake Booster Hose. Its not that hard. Search for Sea Foam and you will find over a hundred threads and how-to's. But to answer your question, You dont need to put so much in your crank case. Make sure to change your oil after a very short drive. Also, it'll be fine in your gas tank.
Old Mar 4, 2006 | 10:07 AM
LudemanDan's Avatar
Default Re: (.xcalibur.)
It should go primarily into your brake booster and/or your pcv valve. After you do that, you should change the spark plugs.
thompson4908
Jun 6, 2011 05:56 AM
PINKS
Oct 18, 2007 04:25 PM
darknessplayboy
Sep 25, 2005 08:06 AM
Tyree
Aug 12, 2004 09:12 PM
civicshowracing65
29
Jul 20, 2004 05:26 AM
