?'s about a B20
Old Mar 25, 2003 | 10:00 AM
spider_man02's Avatar
Default ?'s about a B20
I am trying to swap a b20 into my 99 civic. What do i need to do so and where is a good place to get one?
Old Mar 25, 2003 | 10:11 AM
HondaCutter's Avatar
Default Re: ?'s about a B20 (spider_man02)
you need a flywheel, clutch, transmission, b-series intermediate shaft, rear mount bracket, I think you can use the driver side mount and bracket in an EK, axles, a different b-series intake manifold (if you get the giraffe neck one, I heard you can use the pancake style). I think that might be it, not including the ECU because I think the DX one is supposed to be good enough....
oh, I mean...do a search...
Old Mar 25, 2003 | 10:14 AM
altoid's Avatar
its only cuz you live in maryland that im answering your question.
Need to do an obd2 to obd1 conversion if you want to actually mod the thing later on, or just put in the obd2 if you want to keep it stock. I think the b20b is obd1, someone correct me if im wrong. And you'll have to get a tranny and the appropriate axels, check out http://www.hasport.com for info on swaps and what axels. http://www.hmotorsonline.com is a good place to look for motors so is http://www.importautosalvage.com and http://www.nippon-motors.com Now i must leave cuz its SO GOD DAMMN NICE OUTSIDE!. hope some of this helps
Old Mar 25, 2003 | 11:58 AM
Default Re: ?'s about a B20 (altoid)
no, it's obd2. I have a b20b, it is stamped 96, which is obd2. Plus the injector clips are the ones you just squeeze to get off (obd2 property) and the distributor is single plug (obd2 property) .
I don't see why he would need to convert to obd1, it would just be easier keeping it obd2. I've modded obd2 cars before...
JesterDKing
Mar 16, 2013 04:42 PM
2qwik2nv
Jun 6, 2006 08:44 PM
adeline
12
Mar 20, 2005 06:04 PM
The G2 Racer
10
Oct 15, 2002 06:37 PM
1990CrxSi
21
Aug 6, 2002 05:18 AM
