Runninh With no ps fluid
Old Oct 20, 2008 | 03:46 PM
b20beast83's Avatar
Default Runninh With no ps fluid
I am running my steering rack without any PS Fluid.
The PS Pump is out
Can this damage the rack?
What are the consequences?
Old Oct 20, 2008 | 04:42 PM
jlude90's Avatar
some people say that without it your rack will crap out, but i don't entirely believe that
i have my rack gutted, as well as my last rack and the only issue i have is a bit of play in the wheel, but i haven't tightened up the adjuster bolt to try and see if that would do it
Old Oct 20, 2008 | 04:52 PM
b20beast83's Avatar
Default Re: (jlude90)
my lines are not even looped
just open to the air.
i do hear a clunking noise sometimes when i turn the steering wheel, dont sound like the CV tho.
now sure else what the problem could be?
Old Oct 21, 2008 | 12:42 AM
_BEN_'s Avatar
Default Re: (b20beast83)
Could be a bad ball joint.
I would loop your hoses and ditch the power steering pump. Maybe pour a little fluid into the rack to keep it lubricated.
Old Oct 21, 2008 | 05:54 AM
b20beast83's Avatar
Default Re: (_BEN_)
the rack was leaking.....
so thats why i didnt bother with it
Old Oct 21, 2008 | 12:27 PM
srmofo's Avatar
if the rack is already leaking then it is already bad and needs to be replaced, so whats the difference. if you dont care about the powersteering then just rock it till it gets tough to steer. I would remove the belt off the pwr pump so it doesnt lock up from lack of lube
TLThomson338
Apr 2, 2018 02:08 PM
sneekz206
Feb 1, 2011 03:41 PM
kulo
Jan 24, 2011 03:58 PM
thad
Dec 28, 2005 04:51 PM
mattcalica
Jun 29, 2004 11:10 PM
