Running too lean
Old Aug 12, 2002 | 02:13 AM
  #26
tinkerbell's Avatar
Default Re: Running too lean (Litoman)
OK, do you have a digital volt meter?
tap into teh O2 sensor wire and run it to the cabin, you can watch the O2 voltage as you are driving.
you are right - .5v is middle, <0.5 is lean, >0.5 is rich
it should swing from rich to lean at idle, and go full rich at WOT.
check it out.
what sort of injectors are they? 2-3ohms or 10-12ohms?
t..
Old Aug 15, 2002 | 07:53 PM
  #27
Litoman's Avatar
Default Re: Running too lean (tinkerbell)
I can't seem to find the wire from the O2 sensor. That goes into the ECU. One book says it is the white wire D14. But there is no white wire at D14. The other book says it is a orange/Blue wire C18. But that wire gives me a constent 13V.
Which wire is it?
91blackEF
Apr 5, 2021 03:23 PM
EFb18b
Aug 2, 2015 04:28 PM
manuel3655
May 24, 2007 06:22 AM
dis_epix3
Aug 31, 2006 03:52 PM
im a monster hehe
Feb 20, 2004 09:45 PM
