running rich??
Old Jan 2, 2003 | 11:22 AM
sslude's Avatar
Default running rich??
how bad is it if you are running rich? i heard that the preludes come running rich fromt he factory so you should get a VAFC, so then that means that running a little leaner would help? i am confused.
Old Jan 2, 2003 | 11:26 AM
RaceTilIDie's Avatar
Default Re: running rich?? (sslude)
Running rich means you waste gas, the motor runs cooler, and not to it's power potential. Running lean can damage your motor.
Old Jan 2, 2003 | 11:40 AM
sslude's Avatar
Default Re: running rich?? (RaceTilIDie)
so if i got a VAFC and made it run alittle leaner, that would give me more power and i would save gas? becasue every time i hit vtec, the gas goes down noticably.
Old Jan 2, 2003 | 02:15 PM
tbisme's Avatar
Well, I ran a thread about my d16z6 running too rich and some tried to say that ... no fuel---no power ... and that more is better . There is definatly is a optimum air fuel mixture. It all depends on if you can burn it or not . If you cant, then the space that the unburned fuel is occuping is useless. Replace tha extra fuel with air, and the mixture will burn more efficently. Just remember that if you are going to tune on the edge which is close to lean-----Heat kills
It's always good practice to look at your plugs. Black is fouled - white is too lean. Most shop manuals have colored examples.
Hope I helped -
Old Jan 5, 2003 | 01:49 AM
ED8DX's Avatar
When you start playing with the fuel curves you really should do it while the car is on a dyno. There is a lot of room for messing things up more than you'd like.
DB1_559
Mar 31, 2007 04:40 PM
H22CL
Jun 20, 2004 11:11 AM
jeremy.
Sep 27, 2003 02:12 PM
cruzersi99
Dec 8, 2002 01:59 PM
ludelvr
Sep 28, 2002 09:43 PM
