Running Rich...
Old Jan 10, 2002 | 12:14 AM
Milhouse's Avatar
Default Running Rich...
If I replace my cat with a test pipe....the O2 sensor should read lean and richen up the mixture...
my question is: is it bad for the motor to run rich all the time??
Old Jan 10, 2002 | 05:31 AM
3rdShift.org's Avatar
New User
Default Re: Running Rich... (Milhouse)
It is not "bad", you will burn more gas, have lower EGT's and make less power.
HTH
Old Jan 10, 2002 | 09:17 AM
rainforest's Avatar
Default Re: Running Rich... (3rdShift.org)
rich is better for the motor but leaner ='s more power. like eric(mr2) haha 3rdshift.
Old Jan 10, 2002 | 09:42 AM
pelotudo's Avatar
Default Re: Running Rich... (rainforest)
So, keep a cat on a car, or get a straight pipe/bust out the cat? Which would you suggest on B16a?
Old Jan 10, 2002 | 09:49 AM
New User
Default Re: Running Rich... (PeloTudo)
Test pipe and some sort of air/fuel management. Use an EGT or A/F meter to tune. Go as lean as you can 'til it breaks up and bring it back toward rich.
Old Jan 10, 2002 | 09:53 AM
pelotudo's Avatar
I have the autometer A/F guage installed already. How can I adjust it cheaply and effectively? How big of a "boost" am I going to get from it? Would you just suggest some headers and more bolt ons b4 I start into the fuel management? I was thinking fuel pressure regulator?
Jonathan
Old Jan 10, 2002 | 10:21 AM
976's Avatar
976
New User
An air fuel gauge is only accurate at WOT. I still own one, I like it, but not as accurate as an EGT gauge - esp. made by Apex'i.
I don't recommend gutting your car, it will cause backpressure - well, most of the time, it can be very harsh on your engine.
bigred!
Mar 2, 2009 04:31 PM
JODYG35950
Jan 14, 2006 06:32 AM
Teggyb18b
Dec 1, 2002 06:29 PM
ITR 99
Apr 30, 2002 08:28 PM
HarryB
Mar 28, 2002 08:05 AM
