Running MAP sensor wiring directly to P2T ecu. Possible?
ok so I live in jersey and need to get my turbo 2000 civic si to pass. I plan on putting the stock ecu, and injectors in to pass. The problem is there is no map sensor on my harness. I guess previous own clipped it. Can I run the wires straight from the sensor plug to the ecu? Anyone have the pinouts for the stock b16a2 ecu? Thanks!!
Sorry, no. That's never been an issue for any of the harnesses I've worked on for years. It's just something smart people didn't cut. You need to locate the colored wires matched with a Helms Manual's wiring harness diagram for that chassis.
You could check with Hondata or Omnipower and see if they have the wiring diagram to help you.
you simply use shielded wire and run it to the ecu with some heatshrink butt connectors
https://www.ek9.org/index.php?thread...bd2a-obd1.201/
randol_8o8
Engine Management and Tuning
Jan 7, 2017 01:26 PM
CRXified
35
Dec 29, 2005 07:49 PM
