RPS Carbon Carbon Install. HELP!!
Old Jun 27, 2009 | 12:34 PM
PPLH8R's Avatar
Default RPS Carbon Carbon Install. HELP!!
I am currently installing an RPS carbon twin disk clutch that a customer of mine has had for several years and has lost any directions that may have come with the unit. I have the clutch installed but Iam not sure about which bolts to use to hold the flywheel on to the crank. B-series M/T, D-series M/T or B-series A/T ?
I also have 6 allen head bolts which hold the pressure plate to the flywheel 3 of which have springs on them. I am not sure if all the bolts are supposed to have springs or did a few get lost over the past few years ? I also dont have any kind of torque spec ?
Anyone ?
Old Jun 27, 2009 | 09:40 PM
Blown90hatcH's Avatar
Default Re: RPS Carbon Carbon Install. HELP!!
Ummmm....for what setup?
Old Jun 27, 2009 | 11:52 PM
PPLH8R's Avatar
The motor is a B20 vtec. The transmission is a GSR YS1.
Old Jun 28, 2009 | 04:21 AM
1992Si's Avatar
I'll bet the springs things are lock washers. Either get 3 more or throw them away.
I believe it 19ftlbs of torque on the 6 PP bolts. You'll want to use 6 OEM flywheel bolts that match the crank shaft. I think the crank bolts are 26ftlbs. ?
Check out the parts here,
http://www.acuraoemparts.com/delray/...2)&ListAll=All
Old Jun 29, 2009 | 11:29 AM
PPLH8R's Avatar
I ended up using all the PP bolts without the springs. I torqued them down to 20ft/Lbs.
We shall see.
thanks
angrysmileyface
Sep 14, 2014 05:09 AM
GT40eg
Jul 1, 2007 08:01 PM
90civSi
Apr 10, 2006 08:04 PM
lsvtec101
Jun 7, 2004 09:52 AM
crxgurlllll
11
Dec 10, 2002 09:23 AM
