which flywheel bolts can i use?
i have a comp. clutch twin disk but dont have the bolts. is there any other bolts i can use? i have heard that sohc automatic ones work? does anyone know
SOHC works great!!! I'm a believer in this, the ARP is a little long as well as the B-series too.
ARP bolts if I'm right is designed for stock flywheel
Kept on having lots of issues with the flywheel coming loose after several passes with the B-series fly bolts.(Yes it was torqued)
SOHC are just a tab shorter which gives it a better seating when torqued to specs.
Ever since the SOHC bolts were installed no more flywheel issues after many passes!! G/L and hope it shines some light!
angrysmileyface
09-14-2014 05:09 AM
EvilPinkEye
04-19-2007 07:19 PM
Chillinit
03-12-2005 10:58 AM
