Rounded Flywheel bolts...
Old Jul 23, 2004 | 09:41 AM
GDM Z28's Avatar
Default Rounded Flywheel bolts...
I bought a LS long block from someone local so i can rebuild it. He said the motor was rebuilt 6 months ago but the rings didn't sit right so it smoked and stuff. My friend and I went to go pull the head off and couldn't get the head bolts out and they started to strip. Who ever put them in didn't torque them right. We finally got them out but now we are having trouble with the flywheel bolts. Now they are stripped. My question is what can i try to get them out? If worse comes to worse can i have a machine shop drill them out and helicoil the crank or is that bad? If so why? Any help is appreciated. TIA!
-Trent
Old Jul 23, 2004 | 11:05 AM
vjace's Avatar
Default Re: Rounded Flywheel bolts... (civicflnum1)
hammer on a smaller size socket on the bolt and that should do the trick
i hoped i helped
Old Jul 23, 2004 | 11:41 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
try some vise grips if all else fails
Old Jul 23, 2004 | 01:12 PM
LudeyKrus's Avatar
Well, as tight as the flywheel bolts are torqued on as compared to other bolts on the motor, I don't think normal means will get it off if it's stripped.
I would go straight to Sears and get a set of Bolt-Outs, preferably the impact grade ones if you have an impact gun. Hammer and twist it onto the bolt, stick a BIGASS breaker bar onto the ratchet (say, 4' or so) and go to town.
Old Jul 23, 2004 | 01:17 PM
im_poor's Avatar
Default Re: (LudeyKrus)
try heating up the bolt first. impact hammer w/ a flat tip, maybe it will break it loose,
Old Jul 23, 2004 | 10:49 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Well, as tight as the flywheel bolts are torqued on as compared to other bolts on the motor, I don't think normal means will get it off if it's stripped.
I would go straight to Sears and get a set of Bolt-Outs, preferably the impact grade ones if you have an impact gun. Hammer and twist it onto the bolt, stick a BIGASS breaker bar onto the ratchet (say, 4' or so) and go to town. </TD></TR></TABLE>
I am trying this tomorrow
angrysmileyface
Sep 14, 2014 05:09 AM
nevin
Nov 26, 2003 09:06 PM
Georgethefierce
Aug 3, 2003 08:54 AM
Specialk
May 21, 2003 02:14 PM
vtec69
Oct 31, 2002 07:36 AM
