Rotor Splash shield?
Old Mar 16, 2003 | 05:27 PM
577HondaPrelude's Avatar
Default Rotor Splash shield?
How hard it this to take off? I was looking at it, and it seems you need to take brake calliper and rotor off, just to get the spash shield off.
There has got to be a better way.
Old Mar 16, 2003 | 05:32 PM
tominos's Avatar
Default Re: Rotor Splash shield? (57STS)
you mean the dust shield? you could just cut it with some tin snips.
Old Mar 16, 2003 | 05:34 PM
Chiovnidca's Avatar
And the hub. (If you want to remove it in one peice.)
Old Mar 16, 2003 | 05:38 PM
Default Re: Rotor Splash shield? (D16Chiovnidca)
you call it dust shield but honda calles is spash shield, or spash guard. But ya that thing.
Old Mar 17, 2003 | 07:51 AM
JimBlake's Avatar
Why do you want them off??
I'd call it a splash shield 'cause when they rotted off ('82 Rabbit) the brakes kept getting wet from puddles & they took lots of extra distance to dry off each time I had to stop. It was so obnoxious that I had to put new ones on even though on that car I had to replace the wheel bearings to do it.
Old Mar 17, 2003 | 09:25 AM
Default Re: Rotor Splash shield? (JimBlake)
Because my brakes are getting way to hot out on track. I have had 1 set of brake pads get so hot that they turned brittle and chunks of the pad just came off while driving! This left me with about 1/2 the normal brake size, and stoping took longer than it should. (not fun when your going 100+ mph on track). I have some better "racing" pades on now, but they still get way too hot, after 20min out on track I have white smoke coming off the pades.
I just need more air to get in there to cool things down faster. At least I have yet to catch my pads on fire, which I have seen others do on track days. Fire coming out of the roters is fun to watch though!!
[Modified by 57STS, 1:27 PM 3/17/2003]
Old Mar 17, 2003 | 01:13 PM
desync's Avatar
Why not rig up some sort of vent?
Maybe dryer hose from insde the front grill, to each wheel well and cut a hole in the liner for the hose, that'd force cold air in to the wheel well.
Old Mar 17, 2003 | 03:08 PM
Default Re: Rotor Splash shield? (desync)
Yes, I'm doing that this weekend... but having the air hit the rotor/calaper is better than the air hitting the splash guard, thus I want to take it off. I'm going to just cut it off, taking if off without cutting just seems a big pain in the ***.
Old Mar 17, 2003 | 03:52 PM
Buzz Kill's Avatar
As long as you are aware that the rotor will get wet and increase your stopping distance, you should be fine.
With respect to ducting the brakes, I had very good success using 1" diameter hose. In my CRX si, I had a lot of trouble with ground clearance and with the tire rubbing the hose. The 3 or 4 of the one inch hoses per side could be routed around the front cross member and inside the wheel well.
Old Mar 17, 2003 | 05:29 PM
Echo7847's Avatar
Default Re: Rotor Splash shield? (Buzz Kill)
You have to take the rotor off to get access to the dust shield. Theres a seried of 10mm bolts holding it to the hub, think theres like 3, and you could use a dremel to cut the metal so that it will come off, otherwise you'll have to take the hub off completely to get it off.
EX-T
Feb 18, 2009 11:55 AM
Nat X Stl
Aug 3, 2007 04:38 AM
elnene
Sep 1, 2005 10:16 AM
timmy0tool
May 10, 2005 11:55 AM
Spence
12
Mar 16, 2004 10:24 PM
