Reverse idler gear...is this right? PLEASE HELP!!!!!!!
Old Jul 26, 2007 | 07:32 PM
swappedcx's Avatar
Default Reverse idler gear...is this right? PLEASE HELP!!!!!!!
Is this interlock mounted right? The way it is now the reverse idler gear is all the way down and not meshed with any other gears. Its actually touching the top of the bottom gear...kinda resting on it. Is that mounted right. The bolt for the interlock is mounted in the grove, but I was unsure how the whole setup went back together in that lower area.
Pics are kinda shitty but oh well.
The bolts for the reverse idler gear arm are not in right now, but it sits the same way regardless
Old Jul 27, 2007 | 06:08 AM
Bense's Avatar
do you have anything between the trans housing and the floor/workbench?
if not it will make your mainshaft stick up higher, causing your idler gear to rub against 1st gear on the mainshaft.
Old Jul 27, 2007 | 03:07 PM
swappedcx's Avatar
Default Re: (Bense)
that is true. Also, on the lower parts of the shafts, there are if i recall 3 that form a C shape. Then the interlock with that bronze peice in the middle with the bolt going through the shaft to turn it. Is the interlock and the bronze peice suposed to be in a straight line in the C of the other shafts?
Old Jul 28, 2007 | 09:14 PM
Mista Bone's Avatar
D Tranny Guru
things I do for people, like late night pics on trannys on the workbench
The interlock guide bolt from the clutch side, it gets install AFTER the countershaft has been locked in and case sealed and bolted together.
Another hint about reverse idler gears, the pointy teeth.....
D's =
B's =
Old Jul 28, 2007 | 09:43 PM
4g hatch's Avatar
those are some clear pics and great info. what would happen if u installed the interlock bolt before u bolted it together?
Old Jul 28, 2007 | 09:46 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (4g hatch)
BauleyCivic, a admin/moderator here didn't listen a few years ago while I was teaching him......
he inserted the bolt and it bent the shift arm.......(arm is flipped 180 degrees to show damage) locks it into gear, shifting is not possible, reason I bench shift EACH tranny.
I had warned him.......since because when I was a tranny newbie I did exactly the same thing!
Old D series shift linkage made into bench shifter
Old Jul 28, 2007 | 09:53 PM
4g hatch's Avatar
i replaced a main shaft bearing for a friend and was sure i did it right but when we put the tranny in it would go into gear when the car was off and when it was moving but when u came to a stop and tried for first u had to cut the car off.also never would go into reverse. i still havnt had the heart to take it back apart yet but maybe this was the problem. ill probably just trash it
Old Jul 28, 2007 | 09:58 PM
Mista Bone's Avatar
D Tranny Guru
Comma ,
Period .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">it would go into gear when the car was off</TD></TR></TABLE>
huh? Ghost shifter?
Old Jul 28, 2007 | 10:05 PM
4g hatch's Avatar
always did sleep through english class
Old Jul 30, 2007 | 03:27 PM
swappedcx's Avatar
Thanks guys, those pics would have been super helpful. I put it together that night and everything worked smooth. Super quiet, and changes gears perfect.
Old Jul 30, 2007 | 06:29 PM
4g hatch's Avatar
wish i was that lucky!!!LOL
Old Jul 30, 2007 | 07:47 PM
swappedcx's Avatar
Default Re: (swappedcx)
That was my first tranny to ever rip apart and put together. I pondered how the interlock went together for a good 2hrs. Then got pissed and pulled apart the b series tranny I had sitting in my room and found out it was right.
Actually, I installed the interlock bolt in the clutch housing first. I dont know, it seemed easier to me to see it go in while the case was off and make sure it was in.
Mista Bone, those are awsome pics. Thanks alot!
Old Jul 31, 2007 | 12:49 AM
Mista Bone's Avatar
D Tranny Guru
so easy a caveman can do it?
Old Jul 31, 2007 | 06:14 AM
4g hatch's Avatar
Default Re: (Mista Bone)
i may have to get you to call about car insurance for me also
AllDay-DB8
Transmission & Drivetrain
Jul 14, 2018 06:18 AM
killerpenguin21
10
Jun 3, 2009 02:01 PM
rodimus
Honda S2000
12
Jul 20, 2005 03:57 PM
village_idiot
Apr 1, 2005 06:15 AM
village_idiot
Mar 31, 2005 08:52 PM
