Rethreading Question(s)
Old Jan 6, 2003 | 09:06 AM
94TealGSR's Avatar
Default Rethreading Question(s)
My crank pulley bolt decided that it was ready to come loose, and in doing so it messed up the threads in the crank. What's the best way to go about fixing the threads w/o buying a new crank? I've never used a tap/die before, any instructions would be helpful.
Thanks.
Old Jan 6, 2003 | 09:12 AM
RaceTilIDie's Avatar
Default Re: Rethreading Question(s) (94TealGSR)
Go to Sears, they have most sizes there. Also , get some cutting fluid (oil). Then you will turn it in a little bit and you will feel it cutting, back it out, turn it in again a little further. Repeat the process until it is in to desired depth, adding cutting fluid as you go. I would buy a smaller one and practice on a scrap before doing your crank though.
Old Jan 6, 2003 | 09:50 AM
94TealGSR's Avatar
Default Re: Rethreading Question(s) (RaceTilIDie)
Cool, thanks for the advice. Anyone know the specs on the crank pulley bolt?
Old Jan 6, 2003 | 09:55 AM
If nobody responds, just take the bolt with you to Sears. Grab on of the dial calipers( they are usually just on a cardboard card) and measure the diameter of the bolt. Then count how many threads per inch. If you are off by 1 or 2, it shouldn't matter because they will only have certain pitches.
Old Jan 6, 2003 | 08:58 PM
94TealGSR's Avatar
BUMP, because Home Depot and Sears both said I'm out of luck. Where else can I get a tap/die? I'll check a plain old hardware store tommorow I guess...
Anyone know the specs on a crank pulley bolt?
Old Jan 7, 2003 | 06:34 PM
94TealGSR's Avatar
Ok, here's a picture with specs of the bolt.
I assume I need a 14mmx1.25mm tap and die? I've been looking everywhere (online, at sears/home depot/lowes, etc) and haven't found anything. Anyone know where I can get this tap and die?
Old Jan 7, 2003 | 06:48 PM
hondaeg5's Avatar
ask the snap on tool guy. he can get you the ones you need.
Old Jan 7, 2003 | 06:56 PM
1fastVX's Avatar
Is it stripped out??...if so a tap will not fix it...if it is stripped you can try a helicoil insert to fix it...by the way most local hardware stores do not carry metric stuff....you need to go to an auto parts store....here is a link to the NAPA site for a 14x1.25 Helicoil kit...use this if the threads are shot...good luck!
PS...try searching a little harder...I found this info on metacrawler.com
http://www.napaonline.com/cgi-bin/nc...&usrcommgrpid=
Here is a link for a site that has that tap
http://www.e-taps.com
[Modified by 1fastVX, 4:02 AM 1/8/2003]
Old Jan 7, 2003 | 07:11 PM
94TealGSR's Avatar
Default Re: Rethreading Question(s) (1fastVX)
I looked at the helicoil, I'm just not sure it will stand up to 130ft/lbs of torque... anyone have experience with these things?
Old Jan 8, 2003 | 04:36 AM
1fastVX's Avatar
Here is the website for the manufacter of Helicoil...give them a call and ask them...there is also another thread insert people here on the board have been using...there has been some posts of people using to fix head studs in the block....but I dont remember the name of it....if you search here you will find it
http://www.emhart.com/products/helicoil.html
CT-26_mk3
Other Make Vehicles
Sep 26, 2009 09:20 PM
Midori Green
Jun 3, 2008 07:00 PM
DaKINE-Ek
Aug 14, 2006 05:22 PM
puffsef
Oct 19, 2005 09:50 AM
95lude-s
Mar 17, 2004 01:25 PM
