resetting ECU other than pulling the battery plug?
what's an alternative way to reset the ECU other than from the battery?
EDIT: the reason being is that I dont want to reset my alarm system... it's a pain to setup.... i dont care about radio and clock...
Modified by MileHigh at 4:46 PM 9/30/2003
I believe the factory manual says to...... pull out the 7.5 amp fuse that says "back up", for about 10 seconds, in the fuse box in the engine compartment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxx44 »</TD></TR><TR><TD CLASS="quote">I believe the factory manual says to...... pull out the 7.5 amp fuse that says "back up", for about 10 seconds, in the fuse box in the engine compartment.</TD></TR></TABLE>
yes and make sure the car is up tonormal operating temp. and after u put the fuse back in make sure all accessories in the car are off and start it up...let it idle for about 5 mins shut her down..restart her and your off...either way u will need to reset clock,have radio code if oem...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it »</TD></TR><TR><TD CLASS="quote">
yes and make sure the car is up tonormal operating temp. and after u put the fuse back in make sure all accessories in the car are off and start it up...let it idle for about 5 mins shut her down..restart her and your off...either way u will need to reset clock,have radio code if oem...</TD></TR></TABLE>
so PULLING that fuse is like pulling the battery out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie »</TD></TR><TR><TD CLASS="quote">Just unplug it. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ »</TD></TR><TR><TD CLASS="quote">I just unplug mine, but it's not bolted in at all, so it's easy...
-PHiZ</TD></TR></TABLE>
-Ace
-Ace
Something I read on another forum:
1. warm your engine so that it reaches normal operating temp.
2. disconnect your negative battery lead andf then remove your ECU fuse from the fusebox under the hood for about 8 min.
3. replace fuse, re-connect battery.
4. start engine - DO NOT TOUCH ACCELERATOR PEDAL.
5. allow to idle for about 8min.
6. turn off ignition and wait for 2 min.
7. re-start engine and drive away.
