replacing radiator - 90 civic si, DIY doable?
Hi
i will be replacing my radiator this week. I have a 90 civic si hatch.
Is this replacement straight forward? or is it gonna be difficult?
thanks
franklin
thanks
franklin
I switched 2 at the same time.
From a dx into an Si and vice a versa. Took me 25 - 35 mins for both. LOL
Having a helms makes it easier.
FWIW, I found it easier to remove the lower radiator hose from the block first. Then after I removed the radiator, I swapped it onto the new radiator and installed it. Access gets tight down there otherwise.
If your replacing radiators, upgrade to a 90-93 integra radiator(2-row) vs. civic (1 row). Fits right in only thing is you need to get sightly bigger radiator hoses. Cost is basically the same.
