replacing clutch on 1.5 SOHC QUESTION ???
How many bolts are there holding the transmission to the block ? and also what happens if you dont recut the flywheel ? and were there any other right ups on doing a clutch on this type of motor ? thanks..
I'm gonna be doing a clutch in the next two weeks...here's my writeup on removing the tranny, I will have a clutch install thread soon.
https://honda-tech.com/zerothread?id=596873
6 bolts on d series, 8 on b series holding it to the block. recut, you mean resurface, you dont have to, but its a good idea, i just use an air die grinder with one of those sanding pads, a few times arounf the flywheel surface, or a metl wire cup brush on my 4.5" angle grinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93FastLs »</TD></TR><TR><TD CLASS="quote"> also what happens if you dont recut the flywheel ? </TD></TR></TABLE>
Your clutch wont last as long. Just get it resurfaced. Its about $40.
jeb97gsr
Jan 1, 2007 12:48 PM
integraautox
Jan 23, 2003 01:14 PM
