Replacing the cam holders
Old Sep 23, 2004 | 03:35 PM
ildknyli's Avatar
Default Replacing the cam holders
I was wondering, I had some damage on one of my cam journals and I just got it fix(buffed out). I wanted to replace one or two of the cam holder. Could I just buy the replacement from honda and use it? Or would I need to have it checked and brought up to specs with the journal on the head?
Old Sep 24, 2004 | 08:12 PM
ildknyli's Avatar
Default Re: Replacing the cam holders (ildknyli)
someone knows
Old Sep 25, 2004 | 01:20 AM
Fobtions's Avatar
if u are talkin about the cam caps, you will need to get it line bored to spec.
some machine shops will do it. i suggest getting a new head.
Old Sep 25, 2004 | 01:54 AM
TurboLSVtecTeg's Avatar
Default Re: Replacing the cam holders (Fobtions)
My suggestion depending on how bad they are is either to get them line honed to the stock clearances or get a new head. Honda doesnt sell just the cam caps. They sell that as part of the head. With the head costing 1700+ for a gsr and about the same for any other head basically. I would rather get a used head from someone and go from there instead of getting raped by the damn dealer.
Also what head is this for?? Ive got a few GSR/SI/Type-r cam caps that I have no need for. Its not a complete set but might be useful if you have a vtec head.
Sal
Old Sep 26, 2004 | 08:54 AM
ildknyli's Avatar
Default Re: Replacing the cam holders (TurboLSVtecTeg)
Its for an SI head, they aren't really that damaged. To reword the question, if I replaced them with (Example) some used, non-damaged ones that I bought from TurboLSVtecTeg would I have to get them line bored to spec, if they arnt damaged. Or could I just bolt them on without any mods such as line bored.
Could someone tell me what line bored is?
Old Sep 26, 2004 | 11:40 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ildknyli &raquo;</TD></TR><TR><TD CLASS="quote">Its for an SI head, they aren't really that damaged. To reword the question, if I replaced them with (Example) some used, non-damaged ones that I bought from TurboLSVtecTeg would I have to get them line bored to spec, if they arnt damaged. Or could I just bolt them on without any mods such as line bored.
Could someone tell me what line bored is?</TD></TR></TABLE>
Line boring is exactly what it sounds like. A bar with straight cutting blades on it is passed down the centerline of the cam journals. The cutting diameter of the blades can be varied. This machine is used to make sure that the bearing surface of the cam cap/head is a perfect circle and that all of the journals are in a straight line. Unless your caps are really fubarred I would keep the original ones. If they need it a machine shop can mill down the cap mating surface, torque it down to the head, and recut a new perfect circle.
Old Sep 26, 2004 | 11:02 PM
ildknyli's Avatar
Default Re: Replacing the cam holders (tjbizzo)
Does anyone know what the cutting diameter should be?
Old Sep 27, 2004 | 12:59 AM
junek00's Avatar
You should get a new head anyways, you never know what might happen, just back yourself up!!
Old Oct 10, 2004 | 10:21 AM
ildknyli's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ildknyli &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know what the cutting diameter should be?</TD></TR></TABLE>
Muckman
Sep 11, 2011 04:58 PM
del spool
Nov 28, 2010 02:52 PM
TheCrimsonGhost666
Aug 4, 2010 11:22 PM
njracer
Jan 29, 2008 09:51 AM
blackeg
Dec 30, 2003 11:00 AM
