Replaced ECU and lock assembly - no crank
Old Jul 9, 2016 | 04:53 PM
SinkTip's Avatar
Default Replaced ECU and lock assembly - no crank
2004 Civic 1.7 DX 5 speed.
This car belongs to my 14 year old son. It needs some motor work and was given to him by a family friend who lost the key. The previous owner then took a hammer and screwdriver and tried to break the lock.
I found an ecu and ignition lock assembly (with key) from another car (part numbers were exactly the same) and installed them. Brand new battery, fully charged - was disconnected while the ecu was replaced.
The green key light flashes a couple of times and then goes out. But the motor wont crank over.
What would be the reason the engine won't turn over?
Old Jul 10, 2016 | 10:45 AM
fcm's Avatar
fcm
Old Fart
Default Re: Replaced ECU and lock assembly - no crank
https://honda-tech.com/forums/tech-m...mp%5d-2961164/
Flashing "green light" indicates ECU does not recognize chipped key.
With that said, it cuts off fuel not the starter, something else is wrong. 94
Old Jul 10, 2016 | 01:07 PM
v4lu3s's Avatar
RTFM
you may need to take it to a dealer to reprogram the ecu for that key, might be the fastest fix.
Old Jul 10, 2016 | 03:53 PM
SinkTip's Avatar
The green key light flashes a couple of times then shuts off - same as my 2006 Pilot which runs just fine.
So maybe the starter not spinning is something else.
Duke_royals
23
Dec 20, 2018 07:48 AM
Bryan08
Honda Civic (2001 - 2005)
Aug 29, 2017 07:14 AM
sidewayz32
21
Nov 15, 2005 05:06 PM
NewIntegraKid
Aug 24, 2002 11:24 AM
