Reoccuring idle problem HELP!!!
I have had this problem with surging idle for some time.
Have searched and tried every little fix.
I read through the helms troubleshooting and replaced everything including ecu.
Finally ended up swapping intake manifold(complete) with another that I had and the problem stopped.
Now all of a sudden its doing it again.
Car is 91 integra
When I replaced the IM I also replaced the fuel filter.
Coolant is full and bled of air.
What could be the problem?????
Car is 91 integra
is IACV and FICV the same or different part. I swapped the IACV and didn't help but of course afterward I swapped the whole IM (including IAC) and that fixed it temporarily
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellaboi »</TD></TR><TR><TD CLASS="quote">is IACV and FICV the same or different part. I swapped the IACV and didn't help but of course afterward I swapped the whole IM (including IAC) and that fixed it temporarily</TD></TR></TABLE>
They are seperate parts, the fast idle valve(FICV) is a wierd thermostat kind of thing, usually behind the IM, you`ll find it in Helms..
OK I didn't understand the abbreviation, haven't had much time to check everything again since it started again but that's usually my second or third step. I hope it doesn't need replaced
