Removing rod caps with ARP bolts
I am having a very tough time separating the rod cap from the rod. I pushed them down all the way thinking it would be easier to glide/slide it through, but I can't get it to budge. The rod and cap are not in the motor or on the crank so it makes it a little more difficult. Any tips, ideas?
Dan
Dan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toadfart »</TD></TR><TR><TD CLASS="quote">I pushed them down all the way thinking it would be easier to glide/slide it through</TD></TR></TABLE>
I don't understand what you're saying here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> The rod and cap are not in the motor or on the crank so it makes it a little more difficult.</TD></TR></TABLE>
Actually that makes it a million times easier. Just take a rubber mallet and keep tapping each side of the cap until it starts to separate. Same way you separate the main caps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed »</TD></TR><TR><TD CLASS="quote">
With the original rod bolts, I found it easier to push the cap all the way against the rod and wiggle it loose rather than getting caught on the threads.
Main caps are usually bolted to the block, not in my hands when I break em loose. I'll try the rubber mallet tomorrow. Thanks.
I've always had good luck by putting the rubber handle of a hammer in the middle and tapping on the end of it while holding the rod. Oh, don't let the cap just fall on the ground. lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 »</TD></TR><TR><TD CLASS="quote"> I've always had good luck by putting the rubber handle of a hammer in the middle and tapping on the end of it while holding the rod. Oh, don't let the cap just fall on the ground. lol. </TD></TR></TABLE>
Yeah, I've done that too. Put the handle into the rod bore and use it as a lever to pop the cap off.
TealEG!
May 21, 2008 02:52 PM
