Removing freeze plugs from an intake manifold
Old Jun 4, 2007 | 03:14 PM
vinuneuro's Avatar
Default Removing freeze plugs from an intake manifold
I'm basically doing this with an H22 manifold, but can't find a small enough slide hammer anywhere. What is the next option at removing those plugs?
http://home.comcast.net/~em-engineering/T2T013.pdf (pg 3-4..)
Old Jun 4, 2007 | 05:55 PM
Bailhatch's Avatar
Default Re: Removing freeze plugs from an intake manifold (vinuneuro)
I dont know about intake manifolds, but on engine block freeze plugs, you can just knock them sideways in the hole and pull them out.
Old Jun 4, 2007 | 06:03 PM
vinuneuro's Avatar
Default Re: Removing freeze plugs from an intake manifold (Bailhatch)
The cyl around the plug is too deep and the plug itself is too deep height wise. I tried hitting it with a small punch at the outter edge and the whole plug just got driven down. Could I use an extractor of some sort?
Old Jun 4, 2007 | 06:29 PM
Bailhatch's Avatar
drill a hole in it, then thread in some kind of screw eye or loop of metal on a machine screw. Then stick a handle of some sort through the eye or loop and pry it out.
Old Jun 4, 2007 | 06:33 PM
vinuneuro's Avatar
Screw eye, I hadn't thought of that. Thanks.
almostjdmeg
Dec 7, 2009 07:45 AM
vinuneuro
Jun 4, 2007 09:03 PM
coreyhayman
Sep 29, 2006 06:38 PM
civicracingteam
Feb 14, 2005 07:10 PM
BLKCRX
Jan 2, 2003 01:32 AM
